Icd-u40
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
JerryR
Icd-u40
PostPosted: Sun Oct 07, 2018 4:29 pm     Reply with quote
I have a bunch of CCS ICD-40 debuggers. Are they still usable with CCS IDE? Debugger reports communication error and does not connect. Connects and operates fine with ICD-U64. Thanks
PostPosted: Mon Oct 08, 2018 12:33 am     Reply with quote
They should work.
Just plugged one in, and it is merrily seen by CCSLoad. Had to update the firmware, but it was then recognised, and successfully programmed a chip.
In fact it accepted a chip that a few months ago was 'not supported', following the update. Smile
JerryR
PostPosted: Mon Oct 08, 2018 5:07 am     Reply with quote
Thanks for the reply. I’ll update the firmware and give it a try. Regards
PostPosted: Mon Oct 08, 2018 6:32 am     Reply with quote
Did have an issue a while ago, with a 'not communicating' error, when I tried to use an unpowered hub. Remember they do draw noticeable power.
JerryR
PostPosted: Mon Oct 08, 2018 8:42 am     Reply with quote
Ttelmah:
Thanks again. That may be the issue. I'll use a powered hub and try again.
Regards
drolleman
PostPosted: Mon Oct 08, 2018 3:50 pm     Reply with quote
I have found the most reliable way, is not to use a usb hub at all.
dave
PostPosted: Wed Oct 10, 2018 4:21 pm     Reply with quote
I plug mine directly into the front USB port on my desktop computer and it has
always worked with no problems.
PostPosted: Wed Oct 10, 2018 5:11 pm     Reply with quote
also..
Check the USB port settings it's plugged into.!
Somehow, some program or 'ap' CHANGED the current limit on one of my PC's USB ports ! I have no idea how or when or why...just went through the dbl toothpicks thinking that I had done something.
Once I saw it (using USBView) I was able to change it back to full power.
That was 2-3 years ago..still bugs me that it happened.
Jay
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
